Каждые 12 минут отваливаются ТД Unifi UAP Pro | Ubiquiti форум UBNT: инструкции, настройка
niseimono
30 Сен 2016
Подключили ТД Unifi UAP Pro к Poe-коммутатору Huawei S5720-PWR-56C-EI-AC.
LLDP включен. Точки горят синим, но в логах коммутатора следующее:
Sep 30 2016 13:11:15+03:00 S5720 %%01IFPDT/4/IF_STATE(l)[258]:Interface GigabitEthernet1/0/48 has turned into DOWN state.
Sep 30 2016 13:09:39+03:00 S5720 %%01IFPDT/4/IF_STATE(l)[263]:Interface GigabitEthernet1/0/47 has turned into DOWN state.
Sep 30 2016 12:58:57+03:00 S5720 %%01IFPDT/4/IF_STATE(l)[269]:Interface GigabitEthernet1/0/48 has turned into DOWN state.
Sep 30 2016 12:57:41+03:00 S5720 %%01IFPDT/4/IF_STATE(l)[274]:Interface GigabitEthernet1/0/47 has turned into DOWN state.
Sep 30 2016 12:46:39+03:00 S5720 %%01IFPDT/4/IF_STATE(l)[279]:Interface GigabitEthernet1/0/48 has turned into DOWN state.
Sep 30 2016 12:45:42+03:00 S5720 %%01IFPDT/4/IF_STATE(l)[284]:Interface GigabitEthernet1/0/47 has turned into DOWN state.
Sep 30 2016 12:34:21+03:00 S5720 %%01IFPDT/4/IF_STATE(l)[292]:Interface GigabitEthernet1/0/48 has turned into DOWN state.
Sep 30 2016 12:33:43+03:00 S5720 %%01IFPDT/4/IF_STATE(l)[297]:Interface GigabitEthernet1/0/47 has turned into DOWN state.
Примерно каждые 12 минут точки уходят в DOWN, а затем через несколько секунд поднимаются. И снова по циклу.
Sep 30 2016 16:33:22+03:00 S5720 %%01VBST/6/PORTFORWARD(l)[7]:In VBST VLAN 6, VBST set port GE1/0/47 state as forwarding.
Sep 30 2016 16:33:22+03:00 S5720 %%01VBST/6/PORTLEARNING(l)[8]:In VBST VLAN 6, VBST set port GE1/0/47 state as learnning.
Sep 30 2016 16:33:22+03:00 S5720 %%01VBST/6/PORTDISCARD(l)[9]:In VBST VLAN 6, VBST set port GE1/0/47 state as discarding.
Sep 30 2016 16:33:22+03:00 S5720 %%01IFPDT/4/IF_STATE(l)[10]:Interface GigabitEthernet1/0/47 has turned into UP state.
Sep 30 2016 16:33:16+03:00 S5720 %%01IFPDT/4/IF_STATE(l)[11]:Interface GigabitEthernet1/0/47 has turned into DOWN state.
Может у кого есть версии отчего это происходит?
Спасибо!
N
niseimono
30 Сен 2016
Дык о том и речь, что порты к которым подключены ТД уходят в DOWN, а затем вновь поднимаются и так каждые 12 минут. Явление это не единичное.
Пытаюсь понять, перестает ли ТД посылать какой-нибудь keepalive-сигнал при своём бездействии (сейчас ТД без нагрузки) или в чем-то другом тут дело.
