Unifi Controller на Raspbian Os не доступен в браузере | Ubiquiti форум UBNT: инструкции, настройка
Pavel84
29 Авг 2021
При входе через браузер:
Bad Request
This combination of host and port requires TLS.
На сервере вроде все норм:
pi@raspberrypi:~ $ sudo service unifi status
● unifi.service - unifi
Loaded: loaded (/lib/systemd/system/unifi.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2021-08-29 01:10:37 BST; 7h ago
Process: 529 ExecStart=/usr/lib/unifi/bin/unifi.init start (code=exited, status=0/SUCCESS)
Main PID: 632 (jsvc)
Tasks: 103 (limit: 2059)
CGroup: /system.slice/unifi.service
├─632 unifi -cwd /usr/lib/unifi -home /usr/lib/jvm/java-8-openjdk-armhf -cp /usr/share/java/commons-daemon.jar:/usr/lib/unifi/lib/ace.jar -pidfile /var/run/u
├─633 unifi -cwd /usr/lib/unifi -home /usr/lib/jvm/java-8-openjdk-armhf -cp /usr/share/java/commons-daemon.jar:/usr/lib/unifi/lib/ace.jar -pidfile /var/run/u
├─634 unifi -cwd /usr/lib/unifi -home /usr/lib/jvm/java-8-openjdk-armhf -cp /usr/share/java/commons-daemon.jar:/usr/lib/unifi/lib/ace.jar -pidfile /var/run/u
├─673 /usr/lib/jvm/java-8-openjdk-armhf/jre/bin/java -Dfile.encoding=UTF-8 -Djava.awt.headless=true -Dapple.awt.UIElement=true -Dunifi.core.enabled=false -Xm
└─719 bin/mongod --dbpath /usr/lib/unifi/data/db --port 27117 --unixSocketPrefix /usr/lib/unifi/run --logappend --logpath /usr/lib/unifi/logs/mongod.log --no
Aug 29 01:09:19 raspberrypi systemd[1]: Starting unifi...
Aug 29 01:10:37 raspberrypi unifi.init[529]: Starting Ubiquiti UniFi Controller: unifi.
Aug 29 01:10:37 raspberrypi systemd[1]: Started unifi.
