Решено - Забытая точка не добавляется в контроллер | Ubiquiti форум UBNT: инструкции, настройка
Решено Забытая точка не добавляется в контроллер
Serov
18 Апр 2017
11
Здорово народ.
Забытая точка не добавляется в контроллер. (UniFi AP-AC-LR)
1) Точка была забыта с вебки
2) Версия контроллера была 5.5.20 щас 5.10.25 (думал поможет)
Точку сбрасывал через syswrapper.sh и через кнопку тоже.
И щас точку не видно через веб, но логи ведут на то, что точку видно в логах под старым именем 19-floor Acc02
[2019-07-16T13:20:30,706] <inform-11> INFO inform - from [f0:9f:c2:79:c6:XX](19-floor Acc02, U7LR, 4.0.42.10433): state=INFORM_ERROR, last_inform=135, ext_ip=10.20.103.216, dev_ip=10.20.103.216, up=3733
[2019-07-16T13:22:15,788] <inform-12> INFO inform - from [f0:9f:c2:79:c6:XX](19-floor Acc02, U7LR, 4.0.42.10433): state=INFORM_ERROR, last_inform=105, ext_ip=10.20.103.216, dev_ip=10.20.103.216, up=3838
[2019-07-16T13:24:30,949] <inform-11> INFO inform - from [f0:9f:c2:79:c6:XX](19-floor Acc02, U7LR, 4.0.42.10433): state=INFORM_ERROR, last_inform=135, ext_ip=10.20.103.216, dev_ip=10.20.103.216, up=3974
[2019-07-16T13:26:16,033] <inform-7> INFO inform - from [f0:9f:c2:79:c6:XX](19-floor Acc02, U7LR, 4.0.42.10433): state=INFORM_ERROR, last_inform=106, ext_ip=10.20.103.216, dev_ip=10.20.103.216, up=4079
[2019-07-16T13:28:31,198] <inform-5> INFO inform - from [f0:9f:c2:79:c6:XX](19-floor Acc02, U7LR, 4.0.42.10433): state=INFORM_ERROR, last_inform=135, ext_ip=10.20.103.216, dev_ip=10.20.103.216, up=4214
[2019-07-16T13:30:16,278] <inform-2> INFO inform - from [f0:9f:c2:79:c6:XX](19-floor Acc02, U7LR, 4.0.42.10433): state=INFORM_ERROR, last_inform=105, ext_ip=10.20.103.216, dev_ip=10.20.103.216, up=4319
[2019-07-16T13:32:31,439] <inform-2> INFO inform - from [f0:9f:c2:79:c6:XX](19-floor Acc02, U7LR, 4.0.42.10433): state=INFORM_ERROR, last_inform=135, ext_ip=10.20.103.216, dev_ip=10.20.103.216, up=4454
[2019-07-16T13:34:16,522] <inform-5> INFO inform - from [f0:9f:c2:79:c6:XX](19-floor Acc02, U7LR, 4.0.42.10433): state=INFORM_ERROR, last_inform=105, ext_ip=10.20.103.216, dev_ip=10.20.103.216, up=4559
UBNT-BZ.v4.0.42# info
Model: UAP-AC-LR
Version: 4.0.42.10433
MAC Address: f0:9f:c2:79:c6:XX
IP Address: 10.20.103.216
Hostname: UBNT
Uptime: 5924 seconds
Status: Not Adopted (http://10.20.16.11:8080/inform)
Serov
18 Апр 2017
11
Может кто знает как мак сменить или забыть через cli?
Забыл сказать что контроллер на убунте!
workubnt
25 Мар 2018
355
94
первый вариант: set-inform http://ip-adress:8080/inform
можно его и так:
Access the UAP via SSH, and once in, issue the commands syswrapper.sh restore-default and hit enter. The UAP should quickly reboot with factory default settings. Remember to not disconnect UAP from power source during this process. See Related Articles below if you need guidance on how to SSH into a device.
возможно и эта команда потом понадобится:
set-inform http://10.20.16.11:8080/inform
(set-inform http://ip-adress:8080/inform)
по-моему мак не возможно изменить.
« MAC-адрес присваивается сетевому адаптеру при его изготовлении. Он жестко запрограммирован или жестко запрограммирован на сетевой карте вашего компьютера (NIC) и является уникальным для него. Что-то под названием ARP (Address Resolution Protocol) транслирует IP-адрес в MAC-адрес. ARP похож на паспорт, который получает данные с IP-адреса через фактическое компьютерное оборудование ".
тема на реддите:
https://www.reddit.com/r/homelab/comments/2ozcid/anyway_to_change_the_mac_of_a_unifi_ap/cms5n17/
но зачем это? Это тоже самое что и прошить в опенврт и там Шаманить, но опять зачем это? не стал бы этого делать;)
у меня подобное было. Через wifi от ноута не видел нечего, кроме ssh. Через другой свисток увидел web, сразу заработало.
Serov
18 Апр 2017
11
Спасибо за ответ.
Короче я сам баклан ) точку кто-то мувнул в другой сайт...
Сори за тупость ))
